  #121
Old 26th November 2014, 03:33 AM
RupertPupkin Offline
Re: Programming challenge: Create a GUI window
A while ago rclark posted an example with Pascal using GTK+. It used the Lazarus IDE for Free Pascal to create the form and other project files. I managed to get that example working thanks to his instructions. For anyone (like me) who prefers command-line compiling without an IDE, here's a single-file example of Pascal with GTK+, which requires the fpc package from the Fedora repos.
program pasgtk;
{$mode objfpc}{$H+}
uses Glib2, Gdk2, Gtk2;
procedure destroy(Widget: PGtkWidget; Data: gpointer); cdecl;
begin
   gtk_main_quit;
end;
var win, vbox, lbl, hbox, btn: PGtkWidget; bgcolor : TGdkColor;
begin
   gtk_init(@argc, @argv);
   win := gtk_window_new(GTK_WINDOW_TOPLEVEL);
   gtk_window_set_title(GTK_WINDOW(win), 'Pascal/GTK Window Example');
   gdk_color_parse('darkslateblue', @bgcolor);
   gtk_widget_modify_bg(GTK_WIDGET(win), GTK_STATE_NORMAL, @bgcolor);
   g_signal_connect(G_OBJECT(win), 'delete_event', G_CALLBACK(@destroy), NULL);
   vbox := gtk_vbox_new(FALSE, 0);
   lbl := gtk_label_new(NULL);
   gtk_label_set_markup(GTK_LABEL(lbl), '<span foreground="white" size="32000">Welcome!</span>');
   gtk_box_pack_start(GTK_BOX(vbox), lbl, TRUE, TRUE, 0);
   hbox := gtk_hbox_new(TRUE, 0);
   btn := gtk_button_new_from_stock(GTK_STOCK_OK);
   g_signal_connect(G_OBJECT(btn), 'clicked', G_CALLBACK(@destroy), NULL);
   gtk_box_pack_start(GTK_BOX(hbox), btn, FALSE, FALSE, 0);
   gtk_box_pack_start(GTK_BOX(vbox), hbox, FALSE, FALSE, 10);
   gtk_container_add(GTK_CONTAINER(win), vbox);
   gtk_window_resize(GTK_WINDOW(win), 400, 150);
   gtk_widget_show_all(win);
   gtk_main();
end.
Save that as pascalgtk.pas and compile it like this:
fpc pascalgtk.pas
Screenshot:
Click image for larger version
OS: Fedora 25 x86_64 | Machine: HP Pavilion a6130n | CPU: AMD 64 X2 Dual-Core 5000+ 2.6GHz | RAM: 7GB PC5300 DDR2 | Disk: 400GB SATA | Video: ATI Radeon HD 4350 512MB | Sound: Realtek ALC888S | Ethernet: Realtek RTL8201N
Old 27th November 2014, 07:39 PM
Here's an example in Pascal with XForms. For this you'll need to install the xforms-devel and fpc-src packages from the Fedora repos (yum install xforms-devel fpc-src). The reason is that the XForms bindings in Free Pascal use some XForms functions that have been renamed in the latest XForms libraries. The fix is fairly easy:
  1. First run these commands as root:
    sed -i 's/fl_setpup_fontsize/fl_setpup_default_fontsize/g' /usr/share/fpcsrc/packages/xforms/src/xforms.pp
    sed -i 's/fl_setpup_fontstyle/fl_setpup_default_fontstyle/g' /usr/share/fpcsrc/packages/xforms/src/xforms.pp
    sed -i 's/fl_setpup_color/fl_setpup_default_color/g' /usr/share/fpcsrc/packages/xforms/src/xforms.pp
  2. Then comment out lines 2477-2479 in /usr/share/fpcsrc/packages/xforms/src/xforms.pp like this:
    (* Function fl_setpup_default_fontsize(p1 : LongInt) : Longint;  cdecl;external;
    Function fl_setpup_default_fontstyle(p1 : LongInt) : Longint;   cdecl;external;
    Procedure fl_setpup_default_color(p1 : TFL_COLOR; p2 :  TFL_COLOR); cdecl;external; *)
  3. Next run these commands as root:
    cd /usr/share/fpcsrc/packages/xforms
    make
    cp units/x86_64-linux/xforms* /usr/lib64/fpc/2.6.2/units/x86_64-linux/xforms
You should then be able to use the XForms bindings.
Once you've done all that, save this as pascalxforms.pas:
program pascalxforms;
{$mode objfpc}{$H+}
uses xforms;
var form : PFL_FORM; box, lbl, btn : PFL_OBJECT;
procedure exit_cb(obj : PFL_OBJECT; n : longint);cdecl;
begin
   halt(0);
end;
begin
   fl_initialize(@argc, argv, 'XFormsWindow', nil, 0);
   form := fl_bgn_form(FL_UP_BOX, 400, 150);
   box := fl_add_box(FL_FLAT_BOX, 0, 0, 400, 150, '');
   fl_set_object_color(box, 61, 61);
   lbl := fl_add_text(FL_NORMAL_TEXT, 140, 20, 120, 60, 'Welcome!');
   fl_set_object_color(lbl, 61, 61);
   fl_set_object_lsize(lbl, FL_HUGE_SIZE);
   fl_set_object_lcol(lbl, FL_WHITE);
   fl_set_object_lalign(lbl, FL_ALIGN_CENTER);
   btn := fl_add_button(FL_NORMAL_BUTTON, 175, 110, 50, 30, 'OK');
   fl_set_object_callback(btn, PFL_CALLBACKPTR(@exit_cb), 0);
   fl_end_form;
   fl_show_form(form, FL_PLACE_MOUSE, FL_TRANSIENT, 'Pascal/XForms Window Example');
   fl_do_forms();
end.
Compile it like this:
fpc pascalxforms.pas
Screenshot:
Old 27th November 2014, 09:05 PM
Here's another example in Pascal, this time with Tk. For this you'll need the tk-devel, tcl-devel and fp-src packages installed from the Fedora repos (yum install tk-devel tcl-devel fp-src). The reason is that the Tcl bindings in Free Pascal use an object file (argv.o) that no longer exists, and they use a library (libtcl80.so) that no longer exists. The fix is fairly easy:
  1. As root, run this:
    ln -s /usr/lib64/libtcl.so /usr/lib64/libtcl80.so; ldconfig
  2. Then comment out line 47 in /usr/share/fpcsrc/packages/tcl/src/tcl80.pp like this:
    (*   {$LINK argv.o} *)
  3. Then run these commands as root:
    cd /usr/share/fpcsrc/packages/tcl
    make
    cp units/x86_64-linux/tcl* /usr/lib64/fpc/2.6.2/units/x86_64-linux/tcl/
You should then be able to use the Tcl bindings.
Once you've done all that, save this as pascaltk.pas:
program pascaltk;
uses tcl80;
var interp: PTcl_Interp;
begin
   interp := Tcl_CreateInterp();
   Tcl_Init(interp);
   Tcl_Eval(interp, 'package require Tk');
   Tcl_Eval(interp, 'wm title . "Pascal/Tk Window Example"');
   Tcl_Eval(interp, 'wm geometry . 400x150');
   Tcl_Eval(interp, '. configure -bg "darkslateblue"');
   Tcl_Eval(interp, 'label .lbl -text "Welcome!" -font {-size 32} -bg "darkslateblue" -fg "white"');
   Tcl_Eval(interp, 'pack .lbl -pady 25 -expand 1');
   Tcl_Eval(interp, 'button .btn -text "OK" -command exit');
   Tcl_Eval(interp, 'pack .btn -pady {0 10} -anchor s -expand 1');
   Tcl_Eval(interp, 'tkwait window .');
   Tcl_DeleteInterp(interp);
end.
fpc pascaltk.pas
Screenshot:
Old 27th November 2014, 09:43 PM
Latest update: we now have 100 examples in 43 languages.
Here's a summary of what we have right now, first organized by programming language with the corresponding toolkit:
  1. C: XForms, Motif, MGUI, EZWGL, GTK+, Tk, XView, X Athena Widgets, OpenGL, WINGs
  2. Python: Tk, Qt, GTK+, Swing, Kivy, wxWidgets, FLTK
  3. C++: Qt, FOX, FLTK, GTK+ (gtkmm, c++-gtk-utils), wxWidgets, SDL
  4. Java: Swing, Qt, SWT, AWT, JavaFX, GTK+
  5. Perl: Tk, wxWidgets, Prima, GTK+, Qt
  6. Ruby: Tk, Swing, Qt, FOX, GTK+
  7. Tcl: Tk, GTK+, Qt, FLTK
  8. Pascal: GTK+ (Lazarus, cli), XForms, Tk
  9. R: Tk, Qt, GTK+
  10. Haskell: GTK+, Tk, HGL
  11. Ada: Qt, Tk, GTK+
  12. Scheme: GTK+ (Guile, Gauche), Tk
  13. JavaScript: Swing, jQuery
  14. Lua: Tk, Qt
  15. Matlab: Swing, Matlab GUI
  16. Pure: Tk, GTK+
  17. OCaml: Tk, GTK+
  18. Fantom: FWT, Swing
  19. Lisp: Swing, Tk
  20. Smalltalk: Tk, GTK+
  21. D: GTK+, Tk
  22. BASIC: Qt, GTK+
  23. Objective-C: GNUstep
  24. Icon: Icon
  25. Vala: GTK+
  26. Genie: GTK+
  27. SNOBOL: Tk
  28. Scala: Swing
  29. BeanShell: Swing
  30. Groovy: Swing
  31. Clojure: Swing
  32. Scilab: Tk
  33. ksh: Motif
  34. Julia: Tk
  35. X10: Swing
  36. Nimrod: Tk
  37. Mirah: Swing
  38. ROOT: Xclass
  39. Qore: Qt
  40. Erlang: wxWidgets
  41. Aikido: GTK+
  42. Sather: Tk
  43. Rexx: GTK+
Here's the list organized by toolkit with the corresponding language bindings:
  1. GTK+: Ada, Aikido, BASIC, C, C++ (gtkmm, c++-gtk-utils), D, Genie, Haskell, Java, OCaml, Pascal (Lazarus, cli), Perl, Pure, Python, R, Rexx, Ruby, Scheme (Guile, Gauche), Smalltalk, Tcl, Vala
  2. Tk: Ada, C, D, Guile, Haskell, Julia, Lisp, Lua, Nimrod, OCaml, Pascal, Perl, Pure, Python, R, Ruby, Sather, Scilab, Smalltalk, SNOBOL, Tcl
  3. Swing: BeanShell, Clojure, Fantom, Groovy, Java, JavaScript, Lisp, Matlab, Mirah, Python, Ruby, Scala, X10
  4. Qt: Ada, BASIC, C++, Java, Lua, Perl, Python, Qore, R, Ruby, Tcl
  5. wxWidgets: , C++, Erlang, Perl, Python
  6. FLTK: C++, Python, Tcl
  7. XForms: C, Pascal
  8. FOX: C++, Ruby
  9. Motif: C, ksh
  10. GNUstep: Objective-C
  11. Icon: Icon
  12. Prima: Perl
  13. MGUI: C
  14. EZWGL: C
  15. SWT: Java
  16. AWT: Java
  17. XView: C
  18. JavaFX: Java
  19. jQuery: JavaScript
  20. Kivy: Python
  21. Matlab GUI: Matlab
  22. X Athena Widgets: C
  23. FWT: Fantom
  24. SDL: C++
  25. HGL: Haskell
  26. Xclass: ROOT
  27. OpenGL: C
  28. WINGs: C
In the list organized by toolkit you'll notice that I changed the way the languages are listed so that they are now in alphabetical order, which makes it easier to keep track of the languages each toolkit uses. GTK+ still holds the top spot with 24 examples, followed by Tk with 21 examples. I'm surprised there aren't more bindings for Qt, but I think I might have found a few more so that Qt can start catching up. For languages, C still holds the top spot with 10 examples, which I guess is not surprising given Linux's roots in C.
Old 29th November 2014, 07:21 AM
Here's another example in Pascal, this time with Qt. For this you'll need the Free Pascal Qt4 Binding, which you can get from the Fedora repos (yum install qt4pas qt4pas-devel). Unfortunately there are a couple missing pieces from those packages, but it's easy to get them by running these 6 commands this as root:
wget http://users.telenet.be/Jan.Van.hijfte/qtforfpc/V2.5/demos-V2.5_Qt4.5.3.tar.gz
tar xzvf demos-V2.5_Qt4.5.3.tar.gz
cd demos-V2.5_Qt4.5.3/mainwindow
fpc mainwindow.pas
mkdir /usr/lib64/fpc/2.6.2/units/x86_64-linux/qt4
cp qt4.o qt4.ppu /usr/lib64/fpc/2.6.2/units/x86_64-linux/qt4
You should then be able to use the Qt bindings.
Save this as pascalqtwindow.pas:
program pascalqtwindow;
uses qt4;
var
   app : QApplicationH; win : QMainWindowH; lbl : QLabelH; btn : QPushButtonH;
   style, title, lbltext, btntext : WideString;
begin
   app := QApplication_Create(@argc,argv);
   style := 'QMainWindow, QLabel {background-color: #483D8B; color: #FFFFFF; font-size: 32pt}';
   QApplication_setStyleSheet(app, @style);
   win := QMainWindow_create();
   title := 'Pascal/Qt Window Example';
   QWidget_setWindowTitle(win, @title);
   QWidget_resize(win, 400, 150);
   lbltext := 'Welcome!';
   lbl := QLabel_create(@lbltext, win);
   QWidget_setGeometry(lbl, 90, 25, 220, 50);
   QLabel_setAlignment(lbl, QtAlignCenter);
   btntext := 'OK';
   btn := QPushButton_create(@btntext, win);
   QWidget_setGeometry(btn, 175, 100, 50, 30);
   QObject_connect(btn, '2clicked()', QCoreApplication_instance(), '1quit()');
   QWidget_Show(win);
   QApplication_Exec();
end.
fpc pascalqtwindow.pas
Screenshot:
Old 29th November 2014, 07:44 AM
sonoran Offline
Niklaus Wirth is undoubtedly spinning in his grave.
Old 29th November 2014, 08:10 AM
Yeah, it's a shame he died in that tragic boating accident off Lake Erie. I really liked him in Raising Arizona and those National Treasure movies.
Old 29th November 2014, 09:35 AM
sea Offline
"Shells" (of a sub world)
You wouldnt count a bash script - TUI - for a GUI, right?
Anyway, here it is
#!/bin/bash
#	As good as it gets :p
	. tui # Here, this is only required to print: $TUI_VERSION
	tui-header \
		"TUI $TUI_VERSION" \
		"$($SHELL -version|grep -i ${SHELL##*/})"
	tui-echo
	tui-echo
	tui-echo
	tui-echo
	tui-echo
	tui-title
	tui-title "Welcome!"
	tui-title
	tui-echo
	tui-echo
	tui-echo
	tui-echo
	tui-echo
	tui-press
EFI Cheatsheet :: http://forums.fedoraforum.org/showthread.php?t=298546
Video Handler Script (VHS) (mass re-encode videos, screenrecorder, console music/webradio player, ...) :: http://forums.fedoraforum.org/showthread.php?t=299182
Windows 8+ & Fedora 20+ Dualboot :: http://forums.fedoraforum.org/showthread.php?t=298161
Old 29th November 2014, 11:24 AM
sonoran Offline
Knew I'd regret that, but not how much...
Old 25th April 2015, 05:42 AM
Here's an example in Euphoria with GTK+. You can get Euphoria for Linux here (I used the euphoria-4.1.0-Linux-x64-57179171dbed.tar.gz file): http://sourceforge.net/projects/rapi...a/4.1.0-beta2/
You'll also need the EuGTK toolkit, which you can get here: https://sites.google.com/site/euphoriagtk/Home
Unpack the EuGTK4.9.4.tar.gz file and put the GtkEngine.e and GtkEnums.e files in the same directory as where you would write your Euphoria code. You'll need the gtk3-devel package installed from the Fedora repos for all this to work.
Once you've done all that, save this as eugtkwindow.ex:
include GtkEngine.e
constant msg = `<span foreground='white' size='32000'>Welcome!</span>`
constant win = create(GtkWindow, {{"title", "EuGTK Window Example"},
               {"default size", 400, 150}, {"background", "darkslateblue"},
               {"position", GTK_WIN_POS_CENTER}})
connect(win, "destroy", "Quit")
constant vbox = add(win, create(GtkBox, VERTICAL, FALSE, 0)),
          lbl = pack_start(vbox, create(GtkLabel, {{"markup", msg}}), TRUE, TRUE, 0),
         hbox = pack_start(vbox, create(GtkBox, HORIZONTAL, TRUE, 0), FALSE, FALSE, 10),
          btn = pack_start(hbox, create(GtkButton, "gtk-ok", "Quit"), TRUE, FALSE, 0)
show_all(win)
main()
Assuming that the eui executable for Euphoria is in your PATH (and GtkEngine.e and GtkEnums.e are in the same directory as eugtkwindow.ex), run the code like this:
eui eugtkwindow
Screenshot:
Old 22nd December 2015, 12:30 AM
Here's an example in Falcon with GTK+. Unfortunately the GTK module is not included by default with the Fedora packages for Falcon (even though the Falcon-doc package for F23 does include the GTK+ API!), so you'll have to re-compile Falcon from the SRPM to include GTK support.
Save this script as gtkwindow.fal:
#!/usr/bin/falcon
load gtk
app = GtkMain(args)
class MyWindow from GtkWindow
   function on_delete_event()
      app.quit()
      return false
   end
   function on_clicked()
      app.quit()
   end
   init
      self.set_title("Falcon/GTK Window Example")
      self.modify_bg(GTK_STATE_NORMAL, GdkColor(1, 18481, 15663, 35717))
      self.set_default_size(400, 150)
      self.signal_delete_event().connect(self)
      vbox = GtkVBox(false, 0)
      lbl = GtkLabel('<span foreground="white" size="32000">Welcome!</span>')
      lbl.set_use_markup(true);
      vbox.pack_start(lbl, true, true, 0)
      okBox = GtkHBox(true, 0)
      btn = GtkButton.new_from_stock(GTK_STOCK_OK)
      btn.signal_clicked().connect(self)
      okBox.pack_start(btn, false, false, 0)
      vbox.pack_start(okBox, false, false, 10)
      self.add(vbox)
   end
end
app.run(MyWindow())
Screenshot:
Old 18th February 2017, 05:04 AM
Flounder Offline
This example is a combination of Rust and QML.
src/main.rs
extern crate qml;
use qml::*;
fn main() {
    let mut engine = QmlEngine::new();
    let message = QVariant::from("Welcome!");
    engine.set_property("message", &message);
    engine.load_data("
        import QtQuick 2.0
        import QtQuick.Controls 1.0
        ApplicationWindow {
            title: qsTr(\"Rust/QML Window Example\")
            color: \"#483D8B\"
            width: 400
            height: 150
            visible: true
            Text {
                color: \"white\"
                font.pointSize: 32
                anchors.top: parent.top
                anchors.horizontalCenter: parent.horizontalCenter
                text: message
            Button {
                text: \"OK\"
                anchors.bottom: parent.bottom
                action: Action {
                    onTriggered: Qt.quit()
    engine.exec();
Cargo.toml
[package]
name = "sousa"
version = "0.1.0"
authors = ["Steven Williams <steven.m.williams@yandex.com>"]
[dependencies]
qml = "0.0.9"
You can build and run the code using cargo.
$ cargo new rust-qml-example # to initialize the project
$ cargo build # run this after you have modified main.rs and Cargo.toml to reflect the above snippets.
$ cargo run
Sadly due to my running XMonad, I've been having a good deal of trouble finding a way to get it to float to the right size for pictures, so if someone wouldn't mind doing the honors that would be appreciated.
OS: Arch Linux x86_64
Laptop: Lenovo ThinkPad L440, CPU: Intel Core i7 4702MQ Quad Core 2.20 GHz, Ram: 16GB DDR3, Hard Drive: 500GB, Graphics: Intel 4600 HD, Wireless: Intel 7260AC
Old 18th February 2017, 06:23 AM
Nice, a Rust example! That's the first one here. For Fedora users, here is what I did to compile and run Flounder's example in F25:
  1. As root:
    dnf install qt5-qtquickcontrols rust rust-std-static cargo
  2. As an ordinary user, change to some directory for your Rust code, then do this:
    cd rust-qml-example
  3. Edit the file src/main.rs as in Flounder's post.
  4. Edit the file Cargo.toml as in Flounder's post. This file should be directly in the rust-qml-example directory, not in the src subdirectory.
  5. Run these commands in the rust-qml-example directory:
    cargo build
    cargo run
The 'cargo build' command might take a while, since it has to download and compile the necessary Rust modules (qml, lazy_static, libc). The 'cargo run' command will then produce this window:
Old 20th February 2017, 08:20 AM
osce0 Offline
Not sure a command like yad counts. Yad uses GTK. Here is a one-liner that can run in a shell (doesn't quite meet the background color of window requirement):
yad --width=400 --height=150 --text-align=center \
  --text='<span background=#483D8B font="32">Welcome!</span>' \
  --buttons-layout=center --button=OK:1 \
  --title="Yad GTK+ Window Example"
Last edited by osce0; 20th February 2017 at 08:37 AM. Reason: meet other requirements
challenge, create, gui, programming, window
How do you create your own programming language hmm? Mepoe Programming & Packaging 7 23rd April 2012 12:16 AM
How does KDE 3.7 create popup window on detection of USB drives. Brian1 Using Fedora 0 22nd November 2007 11:12 PM
Which Window Manager are you using for programming ? michaeleekk Programming & Packaging 11 29th July 2007 08:45 AM
gtk programming ~ how to link to another window after button is clicked? yan612 Programming & Packaging 2 3rd October 2006 09:10 AM
Automatic daily login script *Programming Challenge* SickFreak Programming & Packaging 4 23rd November 2005 10:45 PM
Current GMT-time: 02:47 (Monday, 24-07-2017)
